Cliff_Michele wrote:
Dont have a TC yet but what about cutting top sheets and blankets down the middle? When you go to bed you slide in your side and pull your covers over you. No need to wiggle to the top of the bed and then back down. TC on the way but that is our thought.
Don't know about the cutting. We have a king size memory foam mattress in our cabover. Fitted pad and sheet isn't too bad to put on. Then we each have our own top sheet, blanket(s) and spread sort of tucked in on one edge. Getting in and out in the middle is a breeze and with the memory foam, we can often accomplish that without waking the other up. Worked for 15 years so far.
Rick
