- DWeikertExplorer II
fla-gypsy wrote:
Interesting that the burn marks are on the power terminals while the ground looks unscathed. - Veronica26ExplorerLast year, lighting stroke a tree right next to me, it was a very frightening experience and I haven't been out camping since than
- sabconsultingExplorer
sleepy wrote:
tony lee wrote:
except the rubber tires which don't conduct electricity... no ground.. . no worry maybe.
If lightning can jump several miles through air, a little bit of rubber isn't going to worry it too much.
Lighting will always seek the best ground and the easiest circuit... won't it?
My suspicion is that the 'easiest circuit' might be through your camper. I.e. jumping through the aluminum frames and down the cables, tiedowns, etc, then arcing the remaining foot to the ground might be a more attractive route than taking the 12ft through the less conductive air next to the camper.
When at risk of being struck in the desert I attached a heavy duty jumper cable to the aluminum roof rails to act as a lightning rod so any strike would be earthed through that to ground hopefully avoiding frying the camper and vehicle systems as it searched for the best route.
Steve. - camperpaulExplorerMy trailer (with a 32 ft high radio antenna) was about 50 ft from this tree when lightning struck at about 11:00 PM a few years ago.
- pianotunaNomad IIINo.
Wo.ody wrote:
Could anything reasonable be done to a truck camper to be protect it from a lightning strike? - blw2ExplorerI was in a boat struck by lightning years ago.... a boat just like this one.
http://www.buyanad.com/Privates/B635QQ04.jpg
In a rainstorm so we were in the cabin and not on the flying bridge. Vis was bad and we were motoring at idle speed a mile or two offshore I was standing at the back door open to the deck and the rain splash was hitting my legs.
Flash/Bang
I felt the tingle in my wet legs.....
Everything in the boat electrical that was switched on melted. Every lightbulb, every windshield wiper motor, the fuses for thos circits, the electronic ignition module.... all melted or fried.
The wiper motor, lights, etc.. that were switched off were still fine.
We didn't know it untill after the tow to the dock, that the lightning had hit the lightning had struck the CB antenna and blew the top half of it off.
Being in a car is one of the safest places to be. The metal box forms a faraday shield around you. The lightning is only trying to find it's way to ground, and will follow the easiest path. That path is through the metal and AROUND you.
As a pilot, i attended a safety lecture by an engineer envolved with a NASA lightning strike study, and the affects on aircraft. Very fascinating. He was the guy that rode in the back seat of a F-106 intentionaly flown to induce strikes.
Why are you asking? - sleepyExplorer
Lighting will always seek the best ground and the easiest circuit... won't it? - tony_leeExplorer
If lightning can jump several miles through air, a little bit of rubber isn't going to worry it too much. - Shadow_CatcherExplorerStatistically you are about as likely to win the lottery, BUT
I have a canoe that is a bit melty (was on top of a van) one tree that had to be cut down because of multiple strikes and a number of times when the only thing saving the electronics is a whole house surge suppressor and surge suppressors for computers, TV etc.
And no there is no way. - sleepyExplorerHave truck campers being hit by lightning been a big problem... ?
Have automobiles or trucks had a big problem with lightning?
I'm sure that you have already looked into lightning....
what did you find... ?
Do the rubber tires keep campers from being a ground potential for lightning strikes?
If your camper is in contact with earth through the jacks, or the shore power will that make it more likely to get pounded with a lightning bolt?
I never park under lone, tall trees.
Just a thought... my camper never has any sort of contact with earth except the rubber tires which don't conduct electricity... no ground.. . no worry maybe...
It will be interesting
maybe I can go back to worring about RV home invasion
44,029 PostsLatest Activity: Jan 28, 2025
