S Davis wrote:
Grit dog wrote:
@Devo, no skin off my back, and you’re correct, no one with any sort of knowledge about thermodynamics or just good horse sense would disagree that heat rises, aerodynamics are more than partly attributable to frontal area and that the smaller, lighter of a trailer you’re pulling, generally the more economical it is on the fuel bill.
But instead you basically pee’d on every RV owner with a big camper as if your (big 40’ long double and triple axle trailers, which are both sweet btw) choices are somehow morally or physically superior to everyone else’s.
I find it mildly entertaining. Others probably only consider it poor behavior.
The spiteful part is your weird incessant jabbing at anything Ram related because you got either a lemon of a truck or a lemon of a dealer, or both. Anyone with half a brain would have understood that from your initial postings on the issue. But somehow, you got the notion to put down anyone who owns the same brand of truck that YOU bought as well, but are now having a bad experience with it.
A little nit picky but heat doesn’t rise heated air does, heat is omnidirectional and moves from a higher intensity to lower.
That is what I think every time someone says “heat rises” . I normally don’t say anything because it’s usually not worth explaining.
