Me Again wrote:
In the 70's it was 8 gal max in the Seattle area. My 74 K10 SNB had three tanks. OEM 16, 18 saddle on the other side and 30 where the spare tire mounted.
But if the station would only sell you 8 gallons, hauling the extra MT tanks around did you no good. The only advantage was you could go to the station, get 8 gallons wither you needed it or not. In the instance now, the fact you could fill all those tanks means you could be sure 5 other people could not get the 10 gallons they need.
But your talk of the 70s brings up a good point. Nearly 50 years, every once in a while something happens, the oil companies give the sack a good squeeze. Then many try to shake the hand off, but soon we tell them to get another grip. How long before nobody can sing base?
