So, I got distracted while hooking up after a weekend out in our 2012 Keystone Passport. I started to raise the tongue and quickly realized I hadn’t retracted the stabilizer jacks. When I closed ...
It likely did bend but most likely elastic deformation (ie it will spring back once you release the stress). Of course while bent, the slides may get jambed. It also may have damaged some of the plumbing.
Do the slides work smoothly once home and leveled?
