BenK
May 09, 2017Explorer
imq707s wrote:
What are some of the best brake pads you can get for a two vehicle? Something that can stand up to hard braking, without fading on you. I have a set of cheap pads on my Ram 1500, and had them fade to almost nothing while towing my camper down some mountain hills in southern Arkansas.....thank god my trailer brakes were still nice and strong....I ended up using them to slow the truck down....because the truck brakes were completely gone. They were there one minute,then the next thing I know I could put the pedal to the floor and nothing happened...
Very scary situation.....thank god for the manual control on the trailer brakes.
Any suggestion for some good heavy duty pads?
to the PM...this is not just brake pad issue, but starts with the heat generated by the brake pads against cast iron disc...and to that PM asking if my suggested performance brake pads would solve this....NO....just answering the OP's question: "Best brake pads for a tow vehicle?"...am lambasted for 'extra' or 'verbose' info in my answers...can't win on that...this one too little info...so here are more details
'Fad' is composed of two things and can be just one or the other or both at the same time...out gassing lifting the pad material off of the disc surface to create a 'floating' pad with little to no friction material in contact...or in getting hot enough to create out gassing...it will boil the hydraulic brake fluid in the caliper that will then allow the brake pedal to go to the floor
There could also be vaporized brake fluid in the lines...even though it is inches away from the caliper
Vapor in the brake fluid is what this OP has/had experienced because his brake pedal went to the floor. Am sure out gassing was also there, but not the main issue in this instance
Higher performance friction material pads will have the ability to work at a higher temp BEFORE it out gasses, so a kinda sorta fad resistance
Not just towing either, as have experienced brake fad with a 2 seater that ways in around 2,000 lb with me in it...even my other 2 seater that weighs in at 2,400 lbs with me in it...
For this OP, guessing using the TV brakes like most do in non-towing. While towing, best to brake HARD to drop the speed down 10-15 MPH less and then do NOT touch the brakes for a short while to allow them to cool. Then repeat braking HARD to slow down 10-15 MPH and then coast. Repeat that cycle all the way down
Choose a speed you wish to be at, say 55MPH...when your speed goes above by about, say 10 MPH or 65MPH...BRAKE HARD to drop it down to around 50MPH to let it repeat again and again
Of course, other measures to control the speed. Mainly the transmission. A manual would be best, but most today have automatics and that hydraulic coupled TC has that 15% or so slippage to account for
You should be in the lowest gear without over rev'ing the ICE. Diesel's do not have much compression braking, so the why of exhaust brakes that close off the exhaust to have the diesel push exhaust gases into a closed chamber
Anytime brake pads are changed, the brake fluid should be flushed. Best practices that. NEVER top off the MC reservoir either, as it is indicative of the pad wear amount
44,066 PostsLatest Activity: May 16, 2026
