imq707s's avatar
imq707s
Best brake pads for a tow vehicle?
What are some of the best brake pads you can get for a two vehicle? Something that can stand up to hard braking, without fading on you. I have a set of cheap pads on my Ram 1500, and had them fade to almost nothing while towing my camper down some mountain hills in southern Arkansas.....thank god my trailer brakes were still nice and strong....I ended up using them to slow the truck down....because the truck brakes were completely gone. They were there one minute, then the next thing I know I could put the pedal to the floor and nothing happened...Very scary situation.....thank god for the manual control on the trailer brakes.
Any suggestion for some good heavy duty pads?
  • Busdriver wrote:
    I use Wagner, your problem sounds more like bad brake fluid, water in it
    I agree with fluid or master cylinder. I like middle of the road brake pads. The heavy duty metallic pads can be hard on your rotors.
    Brian
  • I use Wagner, your problem sounds more like bad brake fluid, water in it
