4x4ord wrote:
It is too close to call. After posting that remark I read it and realized what I meant to write was:
A 240 HP GL350 pulling a 7300 lb Airstream up a hill should be able to keep up with a 440 hp Powerstroke pulling a 17000 lb fiver up the same hill.
I'd put the money on the GL350 with the Airstream any day. It has a slight hp and torque versus weight ratio but the kicker is the rig pulling the Airstream is using less power to overcome aerodynamic drag. Conversely the PSD pulling a 17K flatbed would likely beat the GL350 pulling a 7300 lb. boxy toyhauler. My disclaimer is that the steeper the hill gets, the less a factor aerodynamic drag is since speed decreases.
