Second Chance wrote:
Lwiddis wrote:
Reconsider staying attached to water in favor of filling with water and using your water pump. Less chance of a burst RV water pipe and flooding.
There is absolutely nothing wrong with staying connected to the park water supply all the time... as long as you have a good quality, adjustable pressure regulator (diaphragm operated - not the straight-through kind - they are just flow restrictors). Our RV waster systems are designed and tested to handle the pressures above and beyond what most parks can muster up. We just find the most affordable potable water hoses on Amazon intended for RV use that have the best overall reviews (and I always read all the negative reviews... they are often complaining about packaging, shipping or something else not related t the product).
Rob
True, until a fitting fails and floods your RV with hundreds of gallons of water. A lot of people shut off the water as a precaution, whether it's the campground supply or their onboard system, when they aren't using it.
