pianotuna wrote:
Hi Bumpyroad,
I had those and thought they were the cat's meow. Unfortunately each of mine developed pin hole leaks. Probably my own fault for not using a pressure regulator.
Bumpyroad wrote:
I did buy a semi-flat/oval standard plastic hose once that was easier to roll up and store however.
bumpy
I've used mine for about 4 years now, quite a bit of use. However, It's a very rare occasion when I stay hooked up to water, and just use mine to fill the onboard tank. As such, the hose seldom sees any real pressure, so if it has or developed a pinhole leak, I'd likely not know it.
It's great for that. takes way less space then a regular hose.
