Lantley
Feb 14, 2018Nomad
hornet28 wrote:Bionic Man wrote:Cummins12V98 wrote:
"Pretty sill to compare a aux tank to a 5 gallon container."
Silly? OK if you say so. I was trying to show that a person may not really NEED a extra fuel tank. Also the fact I have only needed it once. Cost was minimal and to add to the Silly conversation it is very unlikely anyone will pay back the cost.
As I showed a real toolbox is a much better thing to have IMHO.
Your alternative is sill. And off topic.
The OP states that he is looking for something with a capacity between 40 - 70 gallons. And you tell him he should look at a 5 gallon plastic tank that will give him an extra what, 40ish miles, but he still has to stop and pour it into his main tank to use it. He didn't ask for a full tool box and plastic jug. He asked for combo tank experience.
Without exception, when these threads come up, you step in with your opinion that a aux fuel tank isn't "needed". Obviously the OP thinks otherwise.
As far as "payback the cost", for most of us that have an aux tank, it isn't about "paying back the cost". Nor is it a matter of "I can only drive for so long before I have to stop to eat or use the restroom". It is about being able to chose where you stop, not be forced to stop because you have driven for 300 miles and are now out of range.
And, since you already brought this off topic, I can tell you with confidence that I in fact have "paid back" the cost multiple times over.
Now, hopefully we can get back to the posts answering the topic at hand.
Exactly. But some people will never understand such simple logic
I'm considering a aux. tank and I am not sure it is just simple logic. Maybe if you full time and are in constant motion chris crossing the country it is an easy decision. But otherwise is the expense worth the convenience?
Is it worth buying and hailing 50 gallons extra worth of fuel just for the convenience of stopping when you want? Sooner or later you will have to stop just like everyone else.
I don't know the answer but do 18 wheeler's carry extra fuel?
I understand the convenience of the aux. tank but I'm not sure of the economy of the aux. tank.
In the end it all boils down to convenience, time savings and some piece of mind. In order to achieve those goals you pay a little extra which is fine. I have been debating with myself, Do I want the ability/convenience to fuel when I want.
I sort of compare it to my built in Onan genset, which is a expensive option. The Onan provides very convenient power,but there are certainly cheaper ways to power the rig that cost a lot less.
I guess it is simple logic, the Aux. tank is very convenient, if you want that convenience you must be willing to spend the $$$.
Convenience is what you are paying for as the savings will be negligible.
44,070 PostsLatest Activity: Aug 07, 2026
