Marcela wrote:
I would seriously look at henrys tropicool 100% silicone roof coating.
I'll add to this,
Hi TECMike,
How many years do you want to get from your roof coating before you stop using the camper? The cost of the product and time to apply, changes with how many years you want to get.
I have done some in-depth looking and testing into roof coatings as my 16 year roof is getting thinner and I have no intention of selling the camper anytime soon. I have not yet, done a total coating install, but will in time. I have narrowed down the coating to the two below.
There is a need to understand the difference between acrylic coatings and then, silicone coatings and how each react to ponding water. Ponding water can breakdown acrylic coatings in some cases as they not made to handle that environment. Some campers have walk on roofs, others do not. Water sheds different from those two types of roofs.
Next up, are you using the coating to restore the shedding white layer of your old roof, or do you want to deal with all the seams and known leaks points which is wherever caulking was used and the infamous gutter rail area leaks?
There are 2 products that fall into the high solids silicone treatment for roofing. There may be more, but these 2 are the I found so far.
Here is the Henrys Tropical Cool. This system shows a lifetime warranty.
https://henry.com/retail/white-roof-coatings/887-tropi-cool-100-silicone-white-roof-coatingHere is the other, Crazy Seal. This system has a 50 year warranty.
https://crazyseal.com/?msclkid=9dec2a474820129b03794a082dcb511fBoth of them have 3 different viscosities of the product to work on different needs. You use the thicker viscosities over sound older caulk, there is a pump tube for joints if needed and then a open area thinner coating.
Both of these products have to be applied to a very clean surface. Both do work with 1 coat ~ 22 mils thick, but it is better with 2 coats, ~ 40 mill thick.
Both the Tropi Cool and the Crazy Seal have many similarities, the Crazy Seal is infused with fiber where the Tropi Cool is not. Both are rated for buildings and RV's. The Crazy Seal is targeted for the RV'er but rated for buildings. Tropi Cool is targeted for buildings but used on RV's. It is a marketing thing.
The Tropi Cool will most likely be a little cheaper. Both of these coatings will most likely be more expensive then the other RV coatings mentioned in this thread and take longer to install over all the leak prone areas. The end result can be better pending on what you are after.
The big thing I was after is the gutter rails and all the caulk on the roof. That is where the big issues are. As I stated, both products have 3 different viscosity's of the product to go over seams, sound caulking etc. The gutter rails, meaning dealing the the screw area down in the gutter, I had to create my own method to make it work. Over the winter I bought the Crazy Seal product and created test roof samples and applied the product to make sure I knew how it was going to react. The open areas and horizontal area worked flawless as the web site states over caulking and the large roof surface. At the gutter area I had to create a process to deal with them as it is a vertical surface. I have not tested the Tropi Cool product but from reviewing, I expect it to work very similar. If your roof has a large roof radius at the gutter rail that exposes a vertical section of roof, lets talk on how to deal with the vertical surface.
Both of these options create a maintenance free roof other then cleaning and inspection that is rated to last the life of the camper. And they deal with all the caulk issues of the original install.
Three things to note,
1. Any water damage to the roof system from a prior leak, should be repaired before the coating. This includes dealing with crumbling old dried up caulk.
2. Think about replacing all roof mounted plastic before the coating. Shower domes, tank vents, fridge vents etc. This is not a mandate, but dealing with them after the coating will be more difficult.
3. Crazy Seal will not create a long lasting bond to Eternabond. They will tell you that. I suspect Tropi Cool will not either and the same goes for the Dicro acrylic coatings as I have seen it lift on that product too. The top slick surface is the problem. There are ways to deal with this if you used Ebond, it just takes extra steps.
As Marcela stated, look into the high solids silicone coatings as you sort this out.
Hope this helps.
John
