jaycoman89
Feb 17, 2021Explorer
BarneyS wrote:
Probably just need to go inside, remove the AC ceiling cover, look up into the AC and find the 4 long bolts in the corners, and tighten them up a bit. It is quite common for the gasket that seals the AC opening to compress over time and start to leak. The cure, other than replacing the gasket which means removing the AC from the roof opening, is to tighten the bolts a bit.
Barney
Thanks, I'll see about getting down there this weekend and doing that. Anything I need to watch out for when removing the panel? Also, the a/c unit hasn't been running or anything for months. Not sure if that makes a difference in your diagnosis or not.
44,071 PostsLatest Activity: Aug 23, 2026
