opnspaces
Feb 17, 2021Navigator III
If it's dripping next to the AC you will probably see evidence of the drip when you remove the inside AC panel. As stated above just tighten the 4 screws slightly (1/4 to 1/2 turn) There is no way to get Dicor or anything else under the AC unit up on the roof.
Water leaks though can run a long way before they become obvious. Next thing to check is get a ladder and look at the roof itself. Do you see any obvious rips. tears, or cracked caulking? Is the AC looking level and where it should be or is it sinking down into the roof? If it's sinking you have a bigger problem than just tightening the bolts from the inside.
