Old-Biscuit
May 05, 2013Explorer III
I wire brush the rails/teeth.....then spray the rails/teeth will a dry graphite lube. Goes on wet then immediately drys. Will not attract/hold dirt etc.
Also use that on rear stabilizers (worm screw/pivot points) and on front landing gear legs.
For the slide out hydraulic arms I wipe them down with a clean dry cloth and then give them a good wipe with a cloth that has been sprayed with silicone
