Yardvarkers's avatar
Yardvarkers
Best tape
The rear bottom corners on my Jayco Eagle have separated due to some water-I think.I'm looking for a long lasting repair since the camper is not worth much money.I have looked at the possibility of using a strong tape as temporary repair . I now have foil duct tape on the corners but it splits too soon or after about 90 miles.Any and all replies are appreciated.
  • First, I would suggest to find the cause of the water intrusion. If it's from road spray, seal the areas with a sturdy solution like sheet metal, using appropriate sealers to stop further water intrusion. If the water is coming down the interior of the wall frame, seal the roof and any other possible leak areas and then, repair as above.
    Trying to tape together deteriorating wood to siding or trim edges is going to drive you nuts. As the trailer is towed on the road, those surfaces are going to move and any tape is going to fail, eventually. If tape is the only solution, get some of the reinforced "gaffer" tape that is sold to repair coroplast foam panels. It is typically sold at RV dealers but you can get it online. A bit more expensive is Gorilla brand tape, which has a high bond strength.
  • The separation is at the rear of my TT and on the lower part of where the side metal meets the rear metal. Bottom of corner.
  • I'm not entirely sure I understand what you're describing, but I like the idea of the metal plate repair covered with Eternabond tape. Quick, easy, and will likely last quite a while.
  • Eternabond tape. Make sure you follow the directions exactly.
    You can get it at Walmart.
  • I would suggest one foot wide pieces of bent aluminium angle checker plate. Put some screws in where you find studs, and use lots of Sikaflex and some method to hold it all together while the Sikaflex hardens.
