PartyMarty wrote:
Francesca,
it appears to me that all of Michelin's Light Truck tires are S , T , or R speed rated including the load range E tires.
S = 112 mph , T = 118 mph , R = 106 mph .
I do not find any Michelin LT tire with the lowly L rating .
http://www.tirerack.com/tires/TireSearchResults.jsp?customSizeSearch=&width=245%2F&ratio=75&diameter=16
I think lowsuv has it right .
If he's correct, it's only when it comes to the applications for which LT tires are actually
designed, which is for installation on a light truck/SUV.
Did you look at the Michelin links I provided, especially the ones regarding the derating to 75mph of the Michelin Rib when used on an RV/trailer? For purposes of this discussion, that is, as relates to tires for trailers, I think those to be more relevant than any numbers stamped on the tire.
