All of these pages and still confusion ?
If you want to avoid blowouts and tread separation there are some basic things that can be done .
1. inflate to maximum pressure as shown on the tire sidewall .
2. upgrade to a tire ( any brand ) that has a higher load capacity in pounds than the current tires you have.
3. Check your tires each morning for PSI and road hazards . When towing at high speeds place your hand on the sidewalls to see if one tire is hotter than the others at each rest stop . If a tire shows cracking replace it .
4. the ST tire is the weakest link. you will gain reliability by using a 2520 pound load rated tire even on an 1800 # capacity wheel . you still can only carry 1800 # but the tire itself has more and better cords and construction . Run those higher load range tires at the increased PSI shown on the sidewall.
The advantage is that if you start with 65 psi and your tire deflates to 50 psi during that day's trip you still have the same weight capacity as your original 50 psi tires .
5. tire rack charts are your friend . one can compare different tire sizes , Load Ranges ( C , D, E ) and load ratings in pounds versus tire diameter and width .
6. LT tires are load rated to a tougher standard than ST tires . Because of this an 1820 # load rated LT tire is a tougher tire than an ST tire rated at 1820 # . But if you can only get an ST tire then go up in load capacity to say 2271 # or 2520 # or 2830 # based on what is available in an ST .
7. brand is less important than upgrading to a higher load rated capacity tire . A higher load range such as E or D is your friend .
