As a wild guess , I would say only 20 % or so of folks are "motorheads " or "car guys ".
The other 80 % are not and have more important things to do .
such as riding their mountain bike , going to their grandkids soccer games , rooting for their regional sports teams , and the list goes on .
Those are the folks who consider a car an ( disposable ) appliance .
Their car interior gets vacuumed every 6 months and a car wash does not mean a weekly hand wash with loving care .
That same 80 % wants a ONE WORD answer to tire safety for their travel trailer .
The Maxxis faithful give them that one word answer without regard to the facts .
There are no tire tests showing any maxxis tire to be a superior tire.
The solution to preventing catastrophic tire failure are a combination of several actions . In order :
Keep your tires inflated to the maximum psi as indicated on the tire sidewall .
Check for cracking and road hazards frequently .
When replacing your tires increase the load rating in pounds of your replacement tires .If you have 1820 # rated and go to 2271# .
If you have load range C tires , go to load range E or D .
Run those at the max psi shown on the sidewall .
If you can go up a tire width , say from 205 to 215 or 225 that will help also .
LT tires are tested to a tougher standard than ST tires . If you find an LT replacement that fits.
The load rating in pounds found on the sidewall is more important than the brand of the tire .
Maxxis is a third tier tire brand . Michelin , Continental , and Bridgestone are example of tier one brands . Those 3 charge more because they have better tires .
Still it is more important to maintain maximum psi , check for tire deterioration ,and increase the load rating in pounds of your RV tires than brand .
