tattoobob's avatar
tattoobob
Best Truck Battery
Well the time has come to replace my truck Battery, I tested the volts coming out of the Alternator it's putting out 14.5 volts I also cleaned the terminals. thru the process of elimination the battery needs replacing it's original one from 2005 Motorcraft
I'm just wondering what is everyone using for a battery in 2018
  • tattoobob wrote:
    That is true about Napa the only thing is there Batteries only carry a 1 year warranty
    I was thinking of the Walmart Battery Everstart MAXX
    MAXX-65N they have a 5 Year Warranty Program (3 Years Free Replacement + 2 Years Prorated)
    850 CCA (Cold Cranking Amps)
    $93.76†
    I'm on my second WM set in 16 years.
  • I will recommend Autozone Duralast Gold Batteries. I know from experience that they will replace anywhere in the US. I bought an Autozone Durlast Gold in Ridgecrest Ca. I had problems with it in Yuma. They replaced it no questions asked in Yuma.AZ. The battery was still under the full replacement part of the warranty before they pro-rate the cost.
  • Honestly doesn't make a lot of difference. Buying from a large chain store could be handy if you have an issue while traveling but really for a $60-80 battery, I wouldn't worry too much about it.
    Unless you abuse it, you should get several years out of a new battery.
  • GeoBoy wrote:
    I would go to your local NAPA store and get their battery. No matter where your travels take you, there is usually a local NAPA store and they can always get you going.
    Not so. I learned hard way that NAPA is having their regional sellers.
    I bought their alternator when far away from home and when it failed, I had to go 150 miles to the place that belongs to the selling region.
  • That is true about Napa the only thing is there Batteries only carry a 1 year warranty
    $93.76†
  • I would go to your local NAPA store and get their battery. No matter where your travels take you, there is usually a local NAPA store and they can always get you going.
  • Kayteg1 wrote:
    Costco.
    Yep ! My buddy check the spec on the Interstate Batteries at Costco and they were as good as every one else, plus they were about $20 cheaper. Great when you are buying 2 for a diesel.
  • Costco.
    For cars - PepBoys have 96 months warranty on Bosch batteries.
    Also before you dump old battery - consider buying new technology tester sold under Solar.
