jimh406
Mar 08, 2016Explorer III
I don't personally like the combo units. I'd rather have the best tv and best blu-ray with wifi and apps built in for my money. Pay attention to the speakers for whatever tv or combo you buy. Sometimes a few more dollars gives you much better sound.
My Host came with a 17 with articulating mount. The tv rotates 90 degrees and is held in place by velcro straps. I've since updated it to a larger tv because the original insignia died.
I also added an auxiliary tv that has a mount I made that hangs over the cabinet that is across from the dinette. DW or I couldn't see the one in the bedroom wall without sitting on the same side of the dinette. I use a long cables to reach from the main tv or move the source closer as needed.
It's a thin piece of aluminum that I bent to go over the cabinet. The cabinet is open at the top since it is on a slide. I then drilled holes and used screws to attach it to the metal and added some adhesive backed foam tape to it to protect the cabinet. DW created a bag and we store it in the cabinet using some small d rings and bungies to hold it up next to the wall. Sorry, I can't find the pictures. Oh well, I'll have to take more.
