wanderingaimles
Jun 06, 2020Explorer
you mentioned two frequent methods. A third is using a mini split system. Mini splits generally use less power, but are more expensive than a small window unit AC. They are also quieter and more efficient.
Here are several in the appropriate size range of 9000 btu. You would want a 115/120 volt model.
Mini splits
Check you tube there are quite a few video's folks mounting them on trailers.
Mini splits
44,066 PostsLatest Activity: Mar 14, 2015
