joe_julie81's avatar
joe_julie81
Best way to clean tri-lam?
We live in a very humid, moisture laden climate. The tent fabric of the pop-up (tri-lam?) tends to get a little mold / mildew from time to time. I have used diluted bleach and then clear water to wipe it off. I wonder what others are using with good results especially before packing the camper away for a couple of months.
  • I have had good luck with Spray Nine for all types of RV cleaning .
  • I've had good success with Mr. Clean Magic Eraser on the fabrics of all my camper awnings. After cleaning your camper fabric, try using a Mr. Clean Magic Eraser as a follow up. Make it good and wet and simply wipe it over the material and let it dry.
    I have found the chemicals in the Mr. Clean Magic Eraser prevents black and mold growth. One cleaning on my awnings a year and I never have mold or black (dead mashed bugs are a different matter though.)
    Anyway, it's something you might try. Remember, with Mr. Clean Magic Erasers, never scrub a non solid or painted surface. Wipe only, no hard pressure. (If in doubt, test a small area first, see what happens).
    FYI, when we our tent camper (pop-up), I'd clean the fabric, then when dry, spray the dickens out of it with tent spray sealer. It seems to help, until I discovered the Mr. Clean, and then I never had problems again.
    Good luck.
