mackyb's avatar
mackyb
Best Way To Extend Hitch Past Tailgate
I need to tow my TT with the tailgate down in order to haul my ATV in the bed of the truck. With my current set up, this is not possible without the tailgate smashing in to my automatic tongue jack housing during tight turning situations. My WD hitch does not extend far enough out to give maximum turning radius clearance. I have an 7" hitch extension but have read on similar posts that this decreases the hitch capacity by up to 50%. If anybody has an idea how to safely solve this problem, I would like to hear from you. Thanks!
  • It would be pretty easy to remove the jack once everything is loaded and put it back when you need it.
  • Some folks have been able to work around the tailgate vs jack situation by turning the tongue jack 90 degrees. Others, have swapped the jack with one that has a smaller head. If your ATV will fit, maybe, you could remove the tailgate.
