Have used Reese Weight Dist Hist with and without Friction. After a not so good towing experience with the fiction setup and I had a 1 ton van as TV and a 7000 lb trailer in tow. I also installed and setup the Dual Cam. I decided to go with a hitch that did not use friction to control sway, At the time there were 2, Pullrite and Hensley Arrow, Went with the Arrow, Used it on 3 trailers, after setup very easy to use, some say hard to hitch and unhitch but I never had a problem with this. Now having a 5th wheel, If you want something simple to use then get a truck and 5th wheel. No Sway nothing to adjust and easy to use.
