ktmrfs
Dec 18, 2017Explorer III
lanerd wrote:
Ok, you used the word "BEST". That narrows it down to two units. Hensley Arrow or Pro Pride.
Dropping down to "BETTER" narrows it down to three units: Equil-i-zer, Reese Dual Cam, or Blue Ox Sway Pro
Dropping even further down to "GOOD" is any of the el-cheapo units that require a separate sway control bar.
Good summary. With a properly set up trailer IMHO either of the first two categories will more than provide a safe reliable solution.
beyond that it's kinda which one fits you best.
I have the Reese dual cam. love it. but I will admit, as others also will admitt, it isn't a slap together and go setup. you must take care on the initial setup. after that it is "easy peasy"
several folks with trailers in our RV lot have the pro pride and really like it.
Since I have a air safe air hitch the pro pride/hensley likely aren't a good option, Not sure it would work as designed with the air safe.
But then the air safe really makes for a nice ride on concrete expansion joints and frost heaves, and works with most any other WD hitch setup including the equalizer, Reese DC.
