afidel
Dec 19, 2017Explorer II
LVJJJ wrote:
Jumpin' in here again. Started using Equal-I-zer about 20 years ago. Was towing a 30' double slide Arctic Fox with an '88 454 Suburban and for some reason had a big sway problem, just that particular combination I guess. The WD hitch was set up properly, I have known how to do that for a long time. Tried the EQual=I=zer, which solved the problem incredibly well, no sway at all. Used the EQ ever since. When my son bought his first TT I made him by an EQ, he loves it. His dealer tried to sell him a 2 point EQ, (is that a Fastway?). I said don't do it.
The Fastway E2 is fine for lighter to midsized trailers, Fastway is the company that makes the Equilizer and the E2 is their value focused product. Is it as good as the 4 point Equilizer, probably not, but is it sufficient for many setups and a much lower price, for sure. If you've got the money to buy the 4 point EQ then sure, do it, as you've shown it's a well built unit that will last a very, very long time. But if someone doesn't have the spare cash and is going for most half ton towable rigs the E2 works quite well.
