Sort By
- stsmarkExplorerIAMICHABOD and BenK,
A McD field team came and pulled some 6" diameter dents out of the lower wing skin on a Citation Encore that had a tug go underneath the leading edge and also some dents from the leading edge proper. It would have been a pain to patch manually as they were in a wet bay forward of the spar that had some small oval access panels a distance away from the damage.
My pals who watched did not mention any dies so it might have been a variation on the original theme not needing them.
As everything airplane is generally low quantity production and grossly overpriced accordingly, some manufacturer could probably make one for auto use at a price affordable to body shops IMHO, especially given the F150 is probably the tip of the aluminum iceberg. - BenKExplorerThanks for the link to the patent....finished reading it and as thought it had
to be pulsed magnetic forces
Key is the 'die' that the mag forces push the sheetmetal into...guessing some
shapes can't be done this way...if the aspect ratio is to high...it won't or
will require even larger levels of power - IAMICHABODExplorer IIThe device that McDonnell Douglas had was mobile,I moved it many times.
Really neat to see it work. - BumpyroadExplorera quick glance googling US 3998081A seems to me to read that it just uses a powerful magnet to pull the dent out. didn't (in quick cursory reading) about anything on the back side. similar to those that just use a suction cup.
bumpy - stsmarkExplorerGoogle US 3998081A for the patent info and theory of operation.
- stsmarkExplorerIt was created by Mc Donnell Douglas about 2000. Boeing inherited it in the sale. The patents have probably expired.
It's been about 10 years since I saw the results, but not the process.
Mark - BurbManExplorer IIIt says the process restores the material to original strength if not creased and doesn't mar the surface even if painted. Think about the potential for door ding repair....I wonder if it would work on steel? Think of the profit you could roll with a dent-doctor business with a machine that removed the dent in 5 minutes with no surface damage???
- BenKExplorerBut ALU wire with a voltage/current *WILL* develop a magnetic 'field' around the wire...
- vic46Explorer
Bumpyroad wrote:
so how does it create a magnetic field on the back side, can it induce one?
bumpy
HMMMMMMMMMMMMMM:
Aluminum will not work with an induction cooker. Pan/poat must be made of a ferrous metal or have a ferrous metal insert between layers of aluminum. The multi-ply does not work as well as solid ferrous. - BumpyroadExplorerso how does it create a magnetic field on the back side, can it induce one?
bumpy
