egarant's avatar
egarant
Explorer III
Aug 22, 2016
BEWARE! Check your outdoor speakers!
This morning I started on a simple task this morning (or so I thought) to rewire my back up camera from the factory hot lead to my reverse wire to my running lights wire. That way I can simply turn on my lights to see what is behind me.
I pull both rear lamp housings off of my TC so I can see what is what and low and behold behind one of them is wet wires and WET WOOD! Stomach sank.....
My mind quickly scans over the possibilities. I had replaced the shower skylight last year and did my yearly roof inspection just six months ago.
Then I decided to look at the speakers.....they were sealed nicely to the truck, but each speaker cone was completely torn at the bottom. When I washed the truck last night I am sure a ton of water went in each. God knows how long that as been going on.
These are stock Jensen "marine" speakers. I am removing both and sealing p both openings with a round metal/plastic disc. I never use the outdoor ones anyway as there are better bluetooth speakers available for that.
It is going to be very hard to dry out, but I'll do what I can.
My drying out set up....
  • I just purchased two 6" in dia 1/16" inch thick solid aluminum discs that I will paint gloss white then glue in place.
  • Good thing you found it when you did and your in a good area to dry thing out. I have one of these
    https://www.google.com/shopping/product/6745205888056456937?lsf=seller:1135568,store:10420836360621222162&prds=oid:6004449790382719909&q=wood+moisture+meter&hl=en&ei=QkW7V6S9DMGGjwPQtamoBw&lsft=gclid:CKfBiLbU1c4CFYdrfgod-zMMjg
    Works OK, but hard time fitting it into small places. When I dry things out, I dry till I think it's dry then double the time to make sure. (Found that out after my window sills on my house). While a moisture meter is good I still poke at the wood (ice pic or whatever) to make sure there is no dry rot. Main concern is wood swelling and glue coming loose, leading to delamination.
    Somebody on here many months ago, plugged up speaker holes with a piece of plastic, then caulked around them, then put speaker covers back on, couldn't tell the difference in his pic's. Seem like a good idea.
  • jimh425 wrote:
    I'm surprised Eagle Cap has wood there. Good luck!
    The is the outside fiberglass, then a foam core then the interior paneling.
    The side that is wet has a little bit of space between the foam core and outside fiberglass, enough for the water to trickle down. The other side looks to be a tighter seal that prevented (I hope) water from moving down. But it has to go somewhere right?
    I'm going to pull out some other screws on the jacks and seams and see if there is any moisture on them.
  • Hope you can get dried out!
    I will buy a trailer with NO outdoor speakers if possible. I dislike them, but if I ever feel the need for them (as you said) there are better options.
