rjstractor
Oct 31, 2014Nomad
buddylam wrote:
The difference in HP could be the result of higher RPM of a very small amount.
Now if the Alison first gear was very low compared to the Ford and Ram. The DMAX would create a great deal of torque in first gear that might lead to a initial lead that might be insurmountable within a 1/4 mile.
I'll say it a different way. Something stinks.
Either the tests are faulty.
The Dmax is under rated.
The Ford and Ram are over rated.
None of the 3 above have anything to do with my sisters or hookers.
It appears the customer is being deceived in some form. That is what concerns me.
Something that no doubt is a factor is torque management. I don't know how exactly the computers manage it, but you can almost guarantee that none of those trucks have full torque available in first gear. If they did they would need huge driveshafts and axles to avoid drivetrain damage at the hands of a driver lacking common sense. I imagine that is why the Ram Cummins with a 6 speed manual is derated quite a bit from automatic models. I'll bet a software change or two could up the hp and torque to the same as an automatic, but the driver would have to have brains enough to not drop the hammer in low gear with a 20K trailer in tow!
