buddyIam
Oct 31, 2014Explorer
Basically HP is acceleration, torque is twisting power, Your highest HP will be at the point of a curve where the product of RPM and torque is the greatest.
A dyno can not measure HP. It only measures torque and RPM.
Torque times rpm equals power. To compare that to a real horses power you have to divide by the constant 5252.
To rate yourself in elephant power you would have to make an estimate of how much power a elephant makes, make the calculations the same as Watt did, and replace the 5252 constant with your new elephant constant.
The 5252 number is not exact. It's just a number that is used in all HP calculations. It was a steam engine salesman's pitch to sell steam engines.
