buddyIam
Nov 01, 2014Explorer
Turtle,
If Ford is lying then something does stink correct. I find it hard to believe that ford could lie about such a thing as that and not be called on it. It certainly would be easy for these testers to call ford on the numbers. They could rent a dyno and run them on it instead of running a 1/4 mile. But you may be right.
They were all 2015 trucks so the ford would have been the single turbo.
For the ram it is not just that they didn't run the aisin. The aisin also has a higher power cummins with it.
Then there is the mpg numbers. Differences that I haven't seen in tests before. I think it's a given that the dmax gets better mpg. Just not like seen in this test.
