White_Whale
Sep 16, 2016Explorer
kohldad wrote:
Let us know if you need anything else. But with a 91-1/2 dimension between the tie down points, sounds like they moved them farther apart and solved the issue.
Thank you very much for posting those pics and for mentioning the frozen water line. The main reason for buying this Bigfoot is to expand our camping into colder weather periods. I will look at the area of the propane tank as you suggested and insulate the line if needed.
Does your front turnbuckle on the driver's side interfere with your fuel filler cap area?
Also, what do you have between the camper and the truck bed. I had read that two rubber pads and a sheet of 5/8 plywood may be necessary to increase the height of the camper cabover over the truck cab.
44,070 PostsLatest Activity: Jul 01, 2022
