ramrat's avatar
ramrat
Bigfoot Jacks and the CA earthquake
Hi all, got a question about the camper jacks and movement due to the earthquake - what should be checked?
I got the Bigfoot 15C8.2 which i store on my driveway on its jacks only. The driveway has a slightly sloped so the front jacks are up higher than the rear. The camper is set as low as possible. With the AC earthquake my camper moved back and forth and rested about 1/2 foot from its original location.
I will be going to inspect the camper tomorrow. What should I do to visually inspect that no damage was done? I assume making sure the bolts that attach the jacks to the camper is not pulled out. Is there anything else I should be testing (example moving the jacks up and down?)
