sockeye456's avatar
sockeye456
bigfoot window seal
just recently bought a 2000 9.6 bigfoot. one of the outside rubber seal is shrinking and coming out. does anyone know where i can buy new rubber seals? thank you
  • I called Sunview (in 54suds link above), they were very helpful and sold me the rubber extrusion by the foot which arrived only a few days later.
    Now, it is a b***h to get in. Instructions are to put it in hot water to make it more pliable, but these were written by someone who had never done it. It is quite a bit of work, and time consuming, to work it into the aluminum frame. Heat will be long gone before you are 1/4 done - no point. Maybe a sunny day or a heat lamp directed at it while you work would help. But that will no doubt make it shrink more.
    Also, instructions suggest leaving it as long as possible, jamming the ends in to compress the overall length because it will shrink up a bit in length as it settles in. I did my best but it still shrunk away from the ends (this takes a couple of weeks). So next time I do it, I will leave maybe an inch long hanging out at each end, wait a couple of weeks, then compress it as much as possible, cut to length, and stuff the end in. Maybe there is a better way (and I haven't actually tried that one), but that's my best idea.
    If you can't match up at local RV dealer call http://www.dkboosglass.com/ (when checking link is real slow to load)
    I think what your looking for is referred to as "window ribbon"
    Write down manufacture name and all the little tiny numbers in your window, (probably at one of the corners) before you call. Then I would see if you can mail him a 6 inch piece so he can match it up, if he couldn't tell by the numbers you give him over the phone. Then have him mail it or meet up somewhere. He works up and down I-5 fixing RV window glass for dealers and regular people. If you call the office and they refer you another number to call, that is most likely him on his cell phone.
