stevenal wrote:
The dinette window in my old BF was installed in an oversize cutout. The window sat in the lower rear part of the cutout, leaving very little flange and tape to seal the upper forward corner. Shimming it to the center of the cutout was the solution.
I'm surprised folks have an issue with the front window under the cabover. Never had water enter here even when it was wide open.
My front under the cabover has never leaked... That is a very weird place to leak.
If one of the front running lights develop a leak the water can end up anywhere.
The water runs along the insulation foam either left or right... then down going some where... even down inside the sides, following the seams in the foam... I had one leak and it ended up leaking into the passenger side bed storage box.... That one drove me crazy.
Jim
