Jimbee wrote:
Hey All,
We currently have a 2013 Passport 2910 bunkhouse that came equipped with ST205/75 14 Load Range C tires mounted on plain white steel wheels. Would like to upgrade to 15 inch aluminum wheels and tires that would handle the trailer weight a little better and help reduce the risk of a blowout. There is plenty of room in the fender wells to accommodate the bigger tires. Would larger tires have an effect on braking or put to much stress on the wheel bearings?
Thanks!
No. If they did then the design was too close to the margin in the first place. The aluminum wheels would be lighter and could offset the extra weight of the tire anyway. If you have the space then go for it.
