RoyBell
Jun 10, 2015Explorer
Bike mounting- Would like input.
I saw another member with his bikes setup like this and it seems like a great idea. What is everyones thoughts?
1) Is the table safe to travel in the down position? I may put a bit of velcro at the corners to prevent it from sliding. Will it tend to scuff the sides after some miles if it's wedged between the two benches? The only other location I can see storing it is under the sofa, but I will have to rig something up so it doesn't bounce around and go out the side of it.
2) How much does the trailer bounce around inside? The table is just over the axles. I don't have much in the storage there. The bikes combined weight I would guess roughly 50-60 lbs.
I need to figure out how to secure the tires to the plywood. I have some ideas and will look around my shop tomorrow. I am picturing a strap that can use thumb screws to undo and release the tire. Same thing for the plywood. I know we have some double sided bolts, lag on one side and machine thread on the other. I can drive the lag into the bench supports and leave enough poking through the plywood to get a thumb screw on.
I am open to ideas.
20150610_214313 by RoyBelluomini, on Flickr
closed
20150610_214447 by RoyBelluomini, on Flickr
I am open to ideas.
20150610_214313 by RoyBelluomini, on Flickrclosed
