BurbMan wrote:
Anon_Tech wrote:
...outlets with no boxes...
FYI, the outlets they use in RVs are designed to be installed without boxes in shallow-depth walls. The outlets have no exposed contacts and internal cable clamps. Are they using residential outlets with side screws?
The other stuff sounds pretty serious, especially in the main panel. I have the panel cover off in my Heartland Big Country and whoever wired it did a really neat and professional job, I was impressed.
Yes they are using residential outlets, screwed directly into cabinets. No boxes at all. I've hade to go through multiple units and replace all the outlets with enclosed RV ones.
Wade44 wrote:
Perhaps take a good look at the wiring in some of the junk that comes out of Indiana by the big guys. Thor, Forest River, Winnebago, Grand Design etc. I think you would get a good surprise if you poke around the receptacles, shore power connectors, and AC side of converters / distribution panels, and know what your looking for.
Those RVIA decals are a feely good joke and mean nothing.
The RVIA certifies nothing. All that decal says is the manufacturer agrees to follow NFPA1192 which is the National Fire Protection Association. Its a good faith honor system thing as there is no inspector from the NFPA, RVIA, or anyone else in any RV factory anywhere. Read the decal, "Manufacturer certifies".
RVIA is a big circle jerk. NEC article 511 is specifically for RVs though. I'll agree all manufacturers build these things as cheaply as possible. Some are better than others, but almost all of them do atleast try to be mindful of safety if not serviceability.
