time2roll
Feb 21, 2015Nomad
Had a Tornado, it cracked. Replaced with Tornado, stopped spinning/working and was leaking at the fitting.
Replaced with No Fuss Flush that has been perfect. Drilled my own holes for custom spray pattern to focus on sensors and rear of tank. The flimsy plastic supply tube on the Tornado was also troublesome so I got my own fittings and used pex for the No Fuss Flush install. Quicky looks similar and should also work fine.
Yes the backflow is built in. Much better system with one less fitting to break or leak.
44,056 PostsLatest Activity: Nov 19, 2013
