datadr
Jun 10, 2018Explorer
I pulled the underbelly down today on the back half. It was messy and wet and was able to see what happened. The black tank did in fact rupture at the top flange seal across the entire top front of the tank. I wasnt able to get pictures, but it's definitely that. The force of the rupture separated the bracket on one side and the tank is dislodged.
I'll need to pull the other half of the underbelly down as there was a little more effluent on the front part from wicking. There is also some in the floor insulation above the tank from the force of the rushing water out of the tank. There was a small gap in vapor barrier right there, so that will need to come out.
The only good thing from this is that the black tank was emptied before we left the last time we were there, so the only thing really in there was remnants in the bottom of the tank, a few dissolved tank tabs, and fresh water. The smell wasnt that bad overall, considering what happened.
Have someone coming to asses things and see about next steps. A for the neighbor, I have no intention of calling it out and such. They are good people and meant well. I certainly won't thank them for this, as suggested, but they didn't mean harm, and I'm not the kind to want others to be accountable when I should have never had the black tank flush even hooked up without clearly labeling it as such.
Should I be getting that floor insulation out now? I may need to drop the tank out to get to it, which I'm not sure I'm qualified to handle.
