kerry4951
May 28, 2013Explorer
the tc life wrote:
my camper came with a flush system installed that is basically the same thing. those sprays seem to work well. still has not helped the sensor reading though.
only problem i have is that i am rarely at a place that has water and sewer hook ups to use the darn thing.
Alot of the newer TCs are coming thru with the factory installed flush systems. They work very well. They use a female hose fitting that a standard garden hose will screw into. Most dump stations have a basic rubber hose for the user to rinse out his sewer hose when finished, but it has no threaded hose end fitting. I made an adapter that I can clamp onto that hose end and still do my flush, so as long as I am not holding things up I can use their water to flush out my black tank at each dumping. After 3 years my tank sensors are still working fine.
44,071 PostsLatest Activity: Aug 30, 2026
