Executive45
Feb 07, 2014Explorer III
Reach down through the opening and pull it out....might want to use gloves.....:B....Dennis
Make sure you have a blockage. It's always helpful to put as much info in your post trying to describe your issue. If you're pulling the BT handle and nothing happens, perhaps the handle has simply unscrewed from the knife valve. Check the easy stuff first then work backwards. More info from YOU will get more info from US....just sayin....Dennis
44,056 PostsLatest Activity: Mar 02, 2026
