wmoses
Feb 13, 2014Explorer
Komfort 23TS wrote:
OK I guess I have left you hanging long enough. I have an in tank washer put I found out that it really does not work well, it pumps water in but not strong. I could not snake it from top or bottom. So here it comes I used a Draino that does not harm pipes. I went to camping world and got a power wand that you drop in the toilet, I will us that instead of just my in tank washer. Camping world has a sink attachment for the power wand so you will not have to bring a big hose in your trailer. I think using the cg's toilet is not a bad idea! I hope this is a de- stresser for you, thank you for all your help and comments.
Terry,
First of all - thanks for taking the time to update the thread you started with your request for help.
The issue l, and probably some of the others, had is with the fact that each of us spent much of our own good time responding to your request for help and we wanted to see that we did not waste our time. l believe that we must 'give back' in some way when helped, even if it means providing a bit more closure than just saying it was solved. :)
'De-stresser'? Not going there.
As for your solution - it makes sense and worked for you so that is all that matters.
44,066 PostsLatest Activity: Apr 16, 2026
