hohenwald48
Feb 09, 2016Explorer
OldRacer wrote:
just solved the problem today.
straight thru inside the RV replacing the vent/check valve and put a vaccum break check valve on the outside. It screws onto the hose and then into the opening of the trailer. Does the exact same thing.
I don't think it does the same thing. The original was in place to prevent waste tank contents from siphoning from the tank and out thru the garden hose.
The one you installed (assuming it's a hose bib vacuum breaker like you would use on your house) is designed to keep the contents of the garden hose from siphoning back into the waste tank (house). It will allow waste tank contents to siphon out thru the garden hose and into the public water system.
44,056 PostsLatest Activity: Mar 02, 2026
