RussOnTheRoad's avatar
Aug 26, 2023
Question about black tank connection
I'm trying to figure out how my black tank and black tank valve are connected. What the methodology is and what the the white collar is called. Also trying to figure what I may have to do in order to replace the valve which is my plan because it’s sticking pretty badly. (No success with drain valve lube, etc.)
In the photo you can see the black tank on the left. Immediately to the right of the tank there is some sort of white collar, for lack of the proper term. So that's my first question...what is that collar called? Then, it seems the white collar is cemented to the tank. Do I have that right? What would somebody do if that collar got damaged and it’s glued to the tank?
I presume the black tank has a short drain pipe protruding from it and that the white collar covers the junction of the drain pipe and a sewer spigot with flange to which the dump valve is bolted. Do I have that right?
There is a ton of white goo, some sort of sealant I figure, that was used inside the white collar and that spills out in a huge mess, even completely covering two of the bolt heads that attach the valve and flange. What kind of sealant is used for that?
I am fixing to replace the valve but worry I might need to move the white collar for some unanticipated reason so the black tank valve can be removed. I’m not particularly hopeful I would be able to move that collar with all the goop that was used during the OEM installation.
Help me understand what I’m dealing with here in terms of the parts and procedures for replacing the valve beyond that of removing the bolts that hold the valve in place, spreading the pipes a little to remove and replace the valve. I’ve done this before on another RV and spreading the pipes was near impossible. Running into a repeat of that scares me silly, especially because the valve on this RV isn’t real accessible.
Thanks.
