WyoTraveler
Aug 11, 2015Explorer
How do you clean your tank after dumping the black? I use a home a homemade wand down the toilet. Basically high pressures it clean. I noticed on several RVs I have owned a couple of things going on. Sometimes just condensation with a temp change will effect the indicators. At times when mine starts to look full a day later it is less full. I suspect as paper etc. breaks down it also shows errors on the indicators. I just try to make sure every time I dump it shows empty. I use the wand until it does. You need high pressure in the tank to clean it. The wands I have seen at Walmart and RV dealers don't seem to get the job done.
