Lantley
Aug 28, 2022Nomad
dieseltruckdriver wrote:
I wanted to add one more thing that hasn't been posted. Everything in your black tank is something you ate or drank. There's nothing else in there, unless you add a small amount of chemicals. The grey tank is water and soap. The same that you just washed your hands with.
The best part of owning an rv over tenting is having your own private facilities with you. Once you start using it, you will wonder why you waited so long.
Just because it went in your mouth does not mean its germ or bacteria free when it comes out the other end! I'm not sure what your point is!
The grey tank also contains grease , skin folicles and stagnant water.
Waste water water is not germ free. Otherwise we would not need traps to seal off sewer piping.
