traveler1970's avatar
traveler1970
black water tank replacement
Just bought a 1974 Prowler, the black water tank is cracked beyond repair, I would like to build a custom stainless steel replacement, will that work or do I need to replace with a plastic one?
Thank You in advance for your input.
  • Apparently the original plastic tank held in there 40+ years. Planning on keeping it longer than that? I'd go with a new plastic one. Properly installed it's not something that's often a problem.
  • Stainless won't be cheap and not much advantage over ABS plastic. I've bought some fittings from these guys and they seemed very good on customer service, no probs: Tank Depot.
    Good luck with the tank!
  • You are free to do as you wish. The weight if you are towing might be a factor depending on how big and the gauge of the steel.
    Are you going to be towing or is this on a permanent site?
