Passin Thru wrote:
If you get on a untuned Duramax in the low gears your'e liable to tear something up. I have a tuner but run it in #3 position and don't hammer on my accelerator pedal. One of my Duramaxs suffered a major loss due to an Oil pump shaft shearing off. They say Duramax is at fault for not pre oiling the shaft but you can't prove it. Thats an $11K fix.
20 in tires may hit unless you have a lift kit. Besides, the larger the diameter the harder on drivelines because it takes more torque. I have 285/75r16s on Ford aluminum rims on my 06, the hit the mud flaps when turning. Besides the added expense, is it worth it?
My main incentive in going to 20" rims - is the ability to add larger brakes. I've researched the options pretty extensively - and there is a company making GM 8-lug 5 spoke "repro" rims that match exactly the 5 spoke that came with the later year 8x180mm bolt pattern trucks. Except these are in the 8x6.5" pattern for the earlier trucks. They're relatively cheap - at least compared to some aftermarket rims - and they're rated at 3400 pounds apiece (matches OEM specs).
I've looked around to see if there are 18" rims available - but there's only aftermarket stuff - and I can't find anything I really like. I also can't find any larger brakes for these trucks that will fit within an 18" wheel. There's like 5 different options for larger brakes - but they all require 20" wheels.
The brake thing is important to me - it's a safety issue. I live in New England, in heavily suburbanized area outside of Boston - and drivers around here are idiots quite frankly. Plus the brakes on this truck the way they are now - quite frankly suck. I upgraded the brakes on my 2003 Suburban to cryo-treated rotors and Hawk metallic truck pads - and that helped quite a bit, but with a load the thing still didn't stop all that great.
I can see a scenario where I'm towing a trailer that weighs in at 3000-4000 pounds or so - along with maybe another 2000 pounds of weight inside the truck itself. I'd be looking at 12,000 pounds right there - just on the truck brakes. I'd rather be safe than sorry so the brakes are something that are on my list.
The trailer weight requirements for having their own braking system seem to be all over the place. According to this site (for instance):
http://drivinglaws.aaa.com/tag/trailer-brakes/
MA does not require trailer brakes for anything under 10k. (which is way low in comparison to other states)
